New to Midihub: Step-by-Step.01: 9 sockets and more!
As well as the sockets, notice these:
Now…
plug in Midihub to your PC.
(we will connect to Midihub Editor later)
are the lights on?
No? then
  • (old version) switch it on!
  • (2025 version) check your cable!
Your Midihub might be brand-new from the box, or maybe not:
Now… click the button a couple of times
See… how LED 1 flashes then moves on the the next LED…
if you clicked quickly enough!
When you stop clicking, Midihub flashes a few times and stops on that LED…
…You’ve just selected one of Midihub’s 8 presets!
:high_brightness: try cycling through and selecting Presets a few times…
…then check here…
…the “select Preset” cycle is always the same:
:pushpin: This is how you select a Preset when Midihub is not connected to Midihub Editor
Before we connect Midihub to Midihub Editor, try…
..switching off/ unplugging Midihub, then…
..switching back on/ plugging back in
SEE how Midihub returns to the Preset it originally started with.
This is the “Last Stored Preset”
Now Let’s connect Midihub to Midihub Editor!
SbS01_00_Connect
See how the “Current Preset” is shown in the window bar:
Now…
Let’s Load Preset 2:
(Midihub Editor might ask “Do you want to save the pipeline?”. Click Discard)
See how LED 2 is now on:
:pushpin: You can even change the active preset
using a controller...
(…or even your DAW)
if it can send Program Change (PC) messages!
With Midihub connected in Midihub editor…
…choose the DeviceSettings menu:
You’ll see the Program Change Port for Preset Change is Disabled
Set it to the port you want to send PC message into…
…and the MIDI channel to listen on.
Now try it:
  • Program Change = 0 → Preset 1
  • Program Change = 1 → Preset 2
    etc.
if you send Program Change = 8 or more, Midihub will ignore you…
:game_die: What will happen when you Disconnect and “restart” Midihub?
Let's play with that:
Try this a few times…
..click Disconnect:
SbS02_10_Disconn
switch off/ unplug Midihub
switch on/ plug in Midihub
SEE which Preset Midihub starts up with
maybe…
(but not always!)
..use the Button to change the active Preset
Then reconnect to Midihub Editor..
SEE what Editor has as the Current Preset
..then Load another Preset in the Editor
and maybe…
(but not always!)
Store the Preset back in the same slot
(the Store button is next to the Load button)
…and repeat!
You’ll soon see what rules Midihub is following.
Now you know…
  • how to change the Current Preset in the Editor
  • how to change the active Preset with the button when Midihub is stand-alone
  • which LED shows which preset (think live performances!)
  • how to turn Midihub on
lastly…
:pushpin: Watch Out! Very easy to click that button when you’re holding Midihub to push a cable in!
That’s the end of this episode.
In the next episode you’ll make your first patch and learn that the LEDs tell you more than which preset you’re on
The following entries on this topic are helpful comments from users on how to improve the tutorial above.
Many of the suggestions will have already been incorporated.
Feel free to add your own comment or question below!
Needs instruction on where Load Preset menu is located. It’s actually under the Devices menu – shouldn’t Store and Load be under the Presets menu?
I’ve updated the screenshot to indicate that the toolbar menu item was used in that particular case.
The Presets menu is for changing the properties of the current preset, the File menu is for opening, saving, etc… from/to locations available on the main computer, and Device menu is for managing the Midihub device, including its memory contents.
Now you know:
How about a quick explanation of the feature in Settings, that allows you to change the preset via midi messaging? As mentioned in this forum post.
I’ve tried to get that to work, it would be great to use, but what messages does it need to change the preset? Or am I misunderstanding it? Went looking for help and this document seemed to be the closest place I could find for this to be explained.
Hey aA @arcticAnalysis
good idea IMO. Does the following suit?
:pushpin: you can even change the active preset
(…or even your DAW)
PCport4PrChg
PCport4PrChgDropdown
Now try it:
    etc.
(@Blokas: would this fit somewhere at the bottom of the Step-by-Step.01 tutorial? –tried to follow the house-style :wink: !)
This info is just what I needed thanks.
pads
Now I have the 8 pads on my Arturia Minilab MkII configured to switch my Midihub presets.
I am loving the Midihub but to me it lives under the desk, not using up workspace, so this is exactly what I need for this to keep it out of the way, beautiful as it is!
Many thanks @resonotter :medal_sports:
Midihub & Arturia - marriage made in heaven!
Thank you, edited this section into the guide.
