[MODEP] Switchbox plugins not available in BETA RPi5 Patchbox OS
Hi all!
I’ve noticed that plugins like stereoswitchbox, mod-switchbox2, inverted-switchbox, switrchbox 1-2, stereoswitchbox2, and some others aren’t available anymore for download.
I’ve tried copying LV2 plugins from older Patcbox OS image but that didn’t worked out.
I get an error when I try to add the plugin into pedalboard on MODEP.
Any idea how to get these working, these are dealbreaker for me, I’ve tried to find the alternative, but nothing seems to have this function.
Tnx a lot!
@vedranius when I look for available plugins in the Patchstorage interface for “switch” I see the some of the ones you’re mentioning:
What version of patchbox/MODEP are you using? And can you confirm that these are not displayed in your available plugins?
Hm, I’m using the latest, provided on forum here [Beta] Patchbox OS Bookworm ARM64 2024-04-04
But when I’ve firstly booted up MODEP there were no installed plugins at all.
And these switchbox plugins weren’t there.
Not sure what version are you running, but it says LOCAL for you same as for me, and that’s because I’ve manually copied it from older version (RPi4).
What version are you running? That one for RPi5 (BETA)? or?
@jtemple967 this is what I see on a fresh installation of latest BETA RPi5 version
Congrats! You have the latest version: 1.13.0-2 :+1: says when I try to update
@vedranius I tested on my “backup” setup which is a Rpi4. I’ll try with my RPi5 setup and confirm if those plugins are listed.
Hi, sorry, do you have any updates on this?
Tnx!
@Giedrius @Pranciskus so I just checked as well and don’t see the Switchbox 1-2 available to download from Patchstorage within MODEP on my RPi5. I checked and it does indeed have rpi-aarch64 as a platform target:
Conversely the AidaX plugin does show up and has the same targets available. The only differences I see are the Switchbox 1-2 doesn’t have a “Donate” button and uses a different license:
Also, my results when searching for “switch” is the same as @vedranius
hm, so, maybe the version I had copied is from patchbos-os-arm32, so that why it didn’t worked? As it was from older Patchbox OS made for RPi4.
So, if I manually download it for rpi-aarch64, that might work?
But, another problem is that other switchboxes from MOD aren’t available even on Patchstorage for download, for example:
any idea how to get these working?
