MIDI CC overload? Pretty hard crash it seems
Hey, unfortunately the photo got uploaded with a too low resolution to read the contents. Could you get another one uploaded with a higher resolution? If it is the forum software that resizes it, then try some external image host.
To get copyable text, you may try to have an active ssh connection from your computer to RPi, when there’s a big kernel crash, it usually logs the relevant info to all active sessions, you may paste the contents here. (see Raspberry Pi: Remote Control Raspberry Pi via SSH for some tips, ssh access is enabled by default on MODEP images, so just ssh modep@172.24.1.1 (if connecting via the hotspot), use blokaslabs for password)
If the system still accepts commands after the issue has occurred, you can run dmesg to get the entire kernel log, that would be really useful to determine the cause of the issue.
