Today we are releasing a major Pisound mobile app update that introduces a complete new layer of real-time controls. From now on you can tweak the parameters of Pure Data patches within the app, play with the integrated MIDI keyboard and map your external MIDI controllers on the fly!
Big thumbs up goes to @thetechnobear, for his amazing MEC software package, @Patrick_Pagano, who has prepared additional set of great Pure Data patches, and to @mantasb our Android guru!
With the updated app you can:
Navigate between separate parametersâ pages. Change multiple parameters at the same time. Different types of control elements are supported!
Play with the integrated MIDI keyboard. Toggle between different octaves. Enjoy fancy chords with multi-touch support. When playing with an external MIDI keyboard, active notes will light up.
Enter MIDI mode to map your external MIDI controller. Select the parameter you want to map and turn a knob on your controller. You will see the parameterâs position and the value changing. MIDI mapping is saved between sessions!
Steps you need to take to install this update:
Update Pisound software by typing sudo pisound-config and choosing Update Pisound option in a Raspberry Piâs terminal window
Note: We will be publishing a complete guide on how to port your existing Pure Data patches for the updated app on this forum in coming days. Stay tuned!
Just gate it a try (couldnât wait!) and itâs really cool! mapping MIDI controllers is now really easy, and actually I can see this being a thing where you just map the most important things and keep the rest accessible on the app.
I have one little question and a little bug report.
question: does the rpi send out the current MIDI CCs to the attached devices when a patch is loaded? bug: once a patch is running, you have to tap on âcollectionâ before being able to tap on âactiveâ or it wonât react to the tap.
No, it does not, however, we could add that in next version. Which MIDI controller are you using? I guess this is to enable it to display the current values as in the patch?
We have just pushed a minor update to Pisound App that fixes some small navigation issues, to know if you have the updated version, go to âinfoâ before connecting or âaboutâ screens once connected, it should say âVersion: 1.03-2â.
