Is it possible to get the latest Pure Data version ( (0.51-4) in to Patchbox OS? The Patchbox OS pre-installed version is Pd 0.50.2
That’s possible by downloading the PD Debian debs for buster:
First remove PD:
sudo apt remove puredata
sudo apt autoremove
Then install dependencies, download the debs and install them:
sudo apt install tcl tk
mkdir -p /tmp/pd
cd /tmp/pd
wget http://ftp.de.debian.org/debian/pool/main/p/puredata/puredata-core_0.51.4-1~bpo10+1_armhf.deb
wget http://ftp.de.debian.org/debian/pool/main/p/puredata/puredata-gui_0.51.4-1~bpo10+1_all.deb
wget http://ftp.de.debian.org/debian/pool/main/p/puredata/puredata-doc_0.51.4-1~bpo10+1_all.deb
wget http://ftp.de.debian.org/debian/pool/main/p/puredata/puredata-extra_0.51.4-1~bpo10+1_armhf.deb
wget http://ftp.de.debian.org/debian/pool/main/p/puredata/puredata-utils_0.51.4-1~bpo10+1_armhf.deb
wget http://ftp.de.debian.org/debian/pool/main/p/puredata/puredata-dev_0.51.4-1~bpo10+1_all.deb
wget http://ftp.de.debian.org/debian/pool/main/p/puredata/puredata_0.51.4-1~bpo10+1_all.deb
sudo dpkg -i *.deb
sudo apt install pisound-ctl-scripts-puredata
(the links to files taken from Debian -- Details of package puredata in buster-backports)
Thank you, but I recieved some errors. I will do a restart but here is what Terminal said:
Edit: after reboot I still have Pd 0.50.2, still working.
patch@patchbox:/tmp/pd $
patch@patchbox:/tmp/pd $ sudo dpkg -i *.deb
Selecting previously unselected package puredata.
(Reading database ... 81670 files and directories currently installed.)
Preparing to unpack puredata_0.51.4-1~bpo10+1_all.deb ...
Unpacking puredata (0.51.4-1~bpo10+1) ...
dpkg: regarding puredata-core_0.51.4-1~bpo10+1_armhf.deb containing puredata-core:
puredata-core breaks puredata-gui (<< 0.51.4)
puredata-gui (version 0.50.2-3) is present and installed.
dpkg: error processing archive puredata-core_0.51.4-1~bpo10+1_armhf.deb (--install):
installing puredata-core would break puredata-gui, and
deconfiguration is not permitted (--auto-deconfigure might help)
Selecting previously unselected package puredata-dev.
Preparing to unpack puredata-dev_0.51.4-1~bpo10+1_all.deb ...
Unpacking puredata-dev (0.51.4-1~bpo10+1) ...
Selecting previously unselected package puredata-doc.
Preparing to unpack puredata-doc_0.51.4-1~bpo10+1_all.deb ...
Unpacking puredata-doc (0.51.4-1~bpo10+1) ...
Selecting previously unselected package puredata-extra.
Preparing to unpack puredata-extra_0.51.4-1~bpo10+1_armhf.deb ...
Unpacking puredata-extra (0.51.4-1~bpo10+1) ...
dpkg: regarding puredata-gui_0.51.4-1~bpo10+1_all.deb containing puredata-gui:
puredata-gui breaks puredata-core (<< 0.51.4)
puredata-core (version 0.50.2-3) is present and installed.
dpkg: error processing archive puredata-gui_0.51.4-1~bpo10+1_all.deb (--install):
installing puredata-gui would break puredata-core, and
Selecting previously unselected package puredata-utils.
Preparing to unpack puredata-utils_0.51.4-1~bpo10+1_armhf.deb ...
Unpacking puredata-utils (0.51.4-1~bpo10+1) ...
dpkg: dependency problems prevent configuration of puredata:
puredata depends on puredata-core (>= 0.51.4-1~bpo10+1); however:
Version of puredata-core on system is 0.50.2-3.
puredata depends on puredata-gui (>= 0.51.4-1~bpo10+1); however:
Version of puredata-gui on system is 0.50.2-3.
dpkg: error processing package puredata (--install):
dependency problems - leaving unconfigured
Setting up puredata-dev (0.51.4-1~bpo10+1) ...
Setting up puredata-doc (0.51.4-1~bpo10+1) ...
dpkg: dependency problems prevent configuration of puredata-extra:
puredata-extra depends on puredata-core (>= 0.51.4-1~bpo10+1); however:
dpkg: error processing package puredata-extra (--install):
Setting up puredata-utils (0.51.4-1~bpo10+1) ...
Processing triggers for man-db (2.8.5-2) ...
Errors were encountered while processing:
puredata
puredata-extra
patch@patchbox:/tmp/pd $ sudo apt install pisound-ctl-scripts-puredata
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
puredata : Depends: puredata-core (>= 0.51.4-1~bpo10+1) but 0.50.2-3 is to be installed
Depends: puredata-gui (>= 0.51.4-1~bpo10+1) but 0.50.2-3 is to be installed
puredata-extra : Depends: puredata-core (>= 0.51.4-1~bpo10+1) but 0.50.2-3 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Looks like the previous PD was not fully removed. Try doing the following:
sudo apt remove puredata puredata-core puredata-dev puredata-doc puredata-extra puredata-gui puredata-utils
and try the dpkg line again.
Sorry, but I am quite a noob when it comes to Linux.
I got this then:
patch@patchbox:~ $ sudo apt remove puredata puredata-core puredata-dev puredata-doc puredata-extra puredata-gui puredata-utils
pd-comport : Depends: puredata-core but it is not going to be installed or
pd
patch@patchbox:~ $ sudo dpkg -i *.deb
dpkg: error: cannot access archive '*.deb': No such file or directory
patch@patchbox:~ $
Try sudo apt remove pd-comport, and try again.
