Hello
I’ve been trying to find a board to add to my Pi3 which will help make a bat detector. I need to be able to record at least 192kHz and Pisound appears to do that. My current home made mic is electret based with I’m wiring directly to my current sound card (sampling at 96kHz). Once I’ve fitted a suitable jack will this mic be ok with the Pisound?
And one final question - are these boards likely to be available soon?
Hi
I was just just about to check the link again before ordering but the link above no longer seems to take me to anything useful about jumpers, soldering or electrets. Any reason?
@duncanh – did you end up getting a board and making your bat detector? I’m working on DIY streaming hydrophones for listening to echolocation from toothed whales and wonder:
Did you figure out how to solder the jumpers successfully for 5V bias power on the input jack?
If so, I’d really appreciate a photo of your soldered board (ideally with pointers to the jumpers). The documentation you fixed with @Giedrius isn’t quite specific enough for me to get started…
Hi Scott
I decided not to go with a the Pisound as I managed to find one of the Cirrus Logic Pi Audio cards on Ebay at a reasonable price. Also, I’m hoping that AudioInjector get their next project started which will be a 192kHz input/output card for the Pi Zero
