I tried some of the pure data patches which ship with the Pisound setup. for example the minimoog is not controllable via Ctl messages except from modulation, Midinotes note and pitch bend work well. I get the errors below. I had a look in the patches the ctlin objects are not connected. If I connect them it will work but I believe there is another error reason behind this which has to do with the kontrolRack object. is this documented somewhere?
I tried with the fresh installed patchbox os and the image found here https://pi.processing.org/download/ they give the same errors.
thanks
Falk
stopcount-$1: argument number out of range
stopcount2-$1: argument number out of range
KontrolRack: device = kontrol
client connected pd.osc:127.0.0.1:6050
KontrolRack::loading resources
(Tcl) INVALID COMMAND NAME: invalid command name “.x9c01a0.c”
while executing
“.x9c01a0.c delete a06670IN0”
(“uplevel” body line 53)
invoked from within
"uplevel #0 $docmds"KontrolRack: single module mode -> 1
KontrolRack: Enable control monitoring: 1
