sorry to keep you waiting, something came up (well these things always take more time than you imagine). Still intend to finish the project and the write up, but it’ll more likely be mid/end January as right now it’s holiday season here and the hardware is in the lab for two weeks…
I saw that on github. Would patchbox OS benefit from a newer RT Kernel version? The last time I needed a real time kernel I patched the config myself which wasn’t too hard. (but that was 6 years ago on x86 architechture.
Hey, yes, an updated RT kernel would be great. One of the difficulties of updating it is to make sure it runs well at least on Pi 2 - Pi 4 (and all its variations) - we could help with testing it. Another challenge could be Raspberry Pi hardware specific kernel modules that have some code incompatible with realtime kernel mode (like blocking in an interrupt handler, even though it’s a bad idea in itself, is not strictly forbidden in the normal kernel mode, RT kernel would crash or at least dump the stacktrace, slowing the system down to snail speed, if it occurs often )
Hm… I don’t know about the hardware specific kernel modules. This would take some serious investigations. Currently I’m just trying to check out sonic pi. Which has more hidden difficulties than I thought.
But I’m thinking if 64bit would benefit the system as well.
I’m using a 8GB Raspberry Pi4 and a 64bit OS would be lovely! After updating PatchboxOS, I still only have the option to use 4.19.71-rt24 RT kernel (or the vanilla raspberry pi one). Is there a way to get the v5 kernel, and is there any benefit to the 8GB Pi in doing so?
Hi there , just got my pisound and wondering this same question . has anybody made possible to run patchbox OS on 64bit ? would be nice to take advantage of the 8gb in its full potential.
At the moment my soulution is to run latest raspberry OS 64bit and then add manually pi-sound etc , but Im missing all the clever audio overlaying of things and the ease of use of Patchbox for Audio only related work
Hm… Just started from this image, burnt to a new SD card.
Most parts of the patchbox configuration work… except for setting up modules. Say, MODEP.
Manager: modep.module install script found: /usr/local/patchbox-modules/modep/install.sh
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://apt.blokas.io rpi InRelease
Get:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Reading package lists... Done
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Failed to install modep.module via /usr/local/patchbox-modules/modep/install.sh script
Easy fix, it sounds like. Good ol’ sudo apt update, which prompts for an explicit acceptance of that change:
patch@patchbox:~ $ sudo apt update
Do you want to accept these changes and continue updating from this repository? [y/N]
Typed ‘y’ and pressed return.
Got:
Get:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Get:5 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.7 kB]
Get:6 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
Fetched 13.2 MB in 15s (856 kB/s)
Building dependency tree
214 packages can be upgraded. Run 'apt list --upgradable' to see them.
So I did what any normal person would do… sudo apt upgrade.
Processing now.
It’s a long enough process.
Getting some release notes…
apt-listchanges: News
webkit2gtk (2.31.1-1) experimental; urgency=medium
Starting from the 2.31.x development versions, support for NPAPI
plugins has been completely removed from WebKitGTK. This technology is
deprecated and has already been removed from all major web browsers.
The last important user of this API was the Adobe Flash Player, which
reached end of life in December 2020.
-- Alberto Garcia <berto@igalia.com> Fri, 15 Jan 2021 17:31:53 +0100
Then, pressing ‘q’ I get further in the process.
I’ll report back if something goes wrong but I’m sure that part will work well.
I just did an upgrade - now there is there a persistant drum beat in the background, throughout. Whether using different pedalboards or just the OS in desktop mode =)
I’ll have a bash at a new install on a new SD card.
I have today tried to run my new pi4 8gb pisound (I couldn’t get a 4gb one) with the newest nov 2021 build but I had to still follow “clockworks” steps to make it work with the modules.
Also the button is very temperamental and the hotspot is unfindable although I have been able to connect modep directly to a monitor and it functions as expected.
I also have a pisound pi4 4gb which runs perfectly.
Thanks Giedrius,
I tried:
sudo apt update
sudo apt upgrade
…and that worked for getting the modals installed but hot spot is not working.
If I run the above should that fix the hotspot? I’ll give it a go.
PS with this build I tried it on a Pisound with pi 3b and the same problems occurred, ie firstly the modules wouldn’t install then when I got them working the hotspot wasn’t working.
