1.14.2 - A little update that fixes drag & drop between multiple Midihub Editor instances, improves button look in Properties pane for macOS, as well as prevents 1.13.x Editor from interacting with 1.14.x Firmware.
1.14.3 additionally reduces the screen space taken by the mapping buttons.
1.14.4 fixes patching up of Transform pipes during firmware upgrade.
What is the problem in particular? I’ve check the attached file with both 1.14.3 and 1.14.1, both seem to show identical properties for this Transform pipe.
Hey @Giedrius Dragging to a 2nd Editor instance seems to have got broken in 1.14.4:
drags pipes and lines OK, but mappings now all lost with shift-alt-drag.
fuse: failed to exec fusermount: Permission denied
Cannot mount AppImage, please check your FUSE setup.
You might still be able to extract the contents of this AppImage
if you run it with the --appimage-extract option.
See FUSE · AppImage/AppImageKit Wiki · GitHub
for more information
open dir error: No such file or directory
