USB MIDI Serial Converter
Wondering if this could be configured to take a USB midi serial in to Midi out or vice versa
Something like this.
https://www.perfectcircuitaudio.com/mode-machines-cerebelusb.html
Hey, sure, that’s pretty easy to do using ‘aconnect’ ALSA utility. After plugging in the USB MIDI controller to the Raspberry Pi, aconnect -l can be used to list the ALSA midi ports, and then something like:
aconnect 12:0 20:0
aconnect 20:0 12:0
would forward the MIDI data to and from pisound’s serial MIDI ports to the USB MIDI device. The 12:0 and 20:0 numbers would be based on the output of aconnect -l command.
A more graphical approach would be to use aconnectgui utility program to connect the MIDI ports as you wish.
http://terokarvinen.com/wp-content/uploads//2014/08/aconnectgui-drag-small-arrows-to-connect-karvinen.png.png
this is awesome thanks smart person!
