Unable to get the Editor working on Linux - Fedora KDE
Hello. I don’t seem to be able to get the Midihub Editor working at all on my laptop which is running Linux currently. I downloaded the appimage and tried to launch with Gear Lever but nothing happens. I also tried the method on the Fedora Wiki for running appimages but nothing happens.
I’ve got absolutely no clue how to resolve it, any help would be appreciated.
Thanks.
What output do you get if you start it in a terminal / console?
Failed to load client buffer integration: wayland-egl
Failed to load shell integration
Could not create a shell surface object.
xkbcommon: ERROR: /usr/share/X11/locale/en_US.UTF-8/Compose:1661:1: unrecognized keysym “dead_hamza” on left-hand side
xkbcommon: ERROR: /usr/share/X11/locale/en_US.UTF-8/Compose:1662:1: unrecognized keysym “dead_hamza” on left-hand side
xkbcommon: ERROR: /usr/share/X11/locale/en_US.UTF-8/Compose:1663:1: unrecognized keysym “dead_hamza” on left-hand side
xkbcommon: ERROR: /usr/share/X11/locale/en_US.UTF-8/Compose:1664:1: unrecognized keysym “dead_hamza” on left-hand side
xkbcommon: ERROR: /usr/share/X11/locale/en_US.UTF-8/Compose:1665:1: unrecognized keysym “dead_hamza” on left-hand side
This seems similar to Can't launch Midihub Editor in Wayland session
Try starting it like this:
QT_QPA_PLATFORM=xcb ./MidihubEditor_1.15.3.AppImage
Yeah that seems to work. Would be great if I didn’t have to do that of course, but I’m glad that I can use the editor on Linux at least.
Thanks.
Ah, thank you, I had the same issue under KDE Neon (based on Ubuntu 24.04 + up to date KDE stack) !
Can confirm suffering this issue on Arch as well, since most rolling distro`s have switched to wayland recently
I made a shell script for this. That makes it easier to start the editor. So I created this file:
~/bin/midihub
which contains one line:
Next I made this script executable:
chmod +x midihub
Make sure ~/bin is in your PATH.
Next time, I can start it by typing midihub on the cmd line.
Works like a charm.
