just today got hub. remapped all gear as always wanted. 2 modular racks that need 3 midi in’s and microfreak. main clock - digitakt. tho midi from digitakt now can be routed to 1010 bitbox. fantastic.
anyway missing one main thing - conect usb midi controller and route to any midi out. anyway awesome.
This could be worked around if using some host in between the Midihub and the USB MIDI controller, like your laptop, or even a Raspberry Pi, you could set up forwarding of the controller to one of Midihub’s USB ports.
I think can use iPad pro, as it has enough power over usb c and it see it as midi device. will check it more deeply later:)
