hi, Im trying to use the sync delay to sync midi clock. The sync delay is dropping clock (passing start/stop/etc) when set to -1.
Sometimes it starts to work again if set to 0 and then set back to -1, however once powered down it stops passing clock again.
Thank you for the report, we’ll look into that
I found a work around. for -ve values in the Sync Delay run it in parallel with the clock, the sync delay will add the clock ticks, when this is combined with the original clock ticks it functions correctly. NOTE: this will not work for +ve delay.
