Hey!
Trying to add my old script to start a jack_capture instance in tmux (to be able to join into that session to see if everything is running correctly) brings some new problems:
jack is started as user jack which has no bash access and thus makes things difficult. So I guess I need a script which starts tmux as user patch and inside it an instance of jack_capture as user jack to get all the rt things going? This is getting tricky … any ideas?
If I start my script manually I see that everything works in tmux:
patch@MiCROLABS-P3:~$ jack_capture -c 2 -mb -tm -f wav --filename-prefix ABC-TEST- --hook-close ./hookstop.sh --hook-timing ./hookstart.sh
>>> Warning. Could not set higher priority for a SCHED_OTHER process using setpriority().
>>> Waiting to start recording of "ABC-TEST-05.wav"
>>> Press <Ctrl-C> to stop recording and quit.
00:|-----------Press <Return> to start recording------------|
01:|-----------Press <Return> to start recording------------|
Buffer: 3.99s./11.99s Time: 0.00m. DHP: [ ] Overruns: 0 Xruns: 0
but the warnings indicate the above …no high prio for this.
My script looks like this:
#!/bin/bash
/usr/bin/jack_wait -w
tmux new-session -d -s jackd
tmux new-window -t jackd -n Jack Capture -d
sleep 1
tmux send-keys -t jackd:0 'jack_capture -c 2 -mb -tm -f wav --filename-prefix ABC-TEST- --hook-close ./hookstop.sh --hook-timing ./hookstart.sh' C-m
Any idea how to approach this?
As long as the environment from /etc/environment is imported into the current session, you can run jack_capture as ‘patch’ user. It should happen by default, but if it doesn’t, you can force it by putting this in your script:
. /etc/environment # Put it above jack_wait
Try going through the following guide:
http://jackaudio.org/faq/linux_rt_config.html
At the last step, add ‘jack’ user also to the realtime group, let us know how it goes!
I don’t understand why there is no realtime group already? I thought this is already done in Patchbox OS?
usermod -a -G realtime jack
usermod: group 'realtime' does not exist
Should I do it anyways? How does the kernel handle this group realtime? There is a group called audio in Patchbox OS - where jack is already part of (
Edit: okay, the warning is gone by adding the line
* - nice -20 into /etc/security/limits.conf
found it here: https://linuxmusicians.com/viewtopic.php?t=11454#p46621
Okay, since this works more or less … I am trying to figure out why my systemd which launches the script is behaving totally differently as if I launched the script manually - now I get even more Warnings/Errors:
jack_capture -c 2 -mb -tm -f wav --filename-prefix ABC-TEST- --hook-close ./hookstop.sh --hook-timing ./hookhook-timing ./hookstart.sh
Cannot lock down 82287136 byte memory area (Cannot allocate memory)
Cannot use real-time scheduling (RR/70)(1: Operation not permitted)
JackClient::AcquireSelfRealTime error
Can you show us your entire .service file? All systemd services start with ‘empty’ environment, this could be the cause. The EnvironmentFile=/etc/environment is mandatory for services working with Jack backend.
Description=Jack Capture autostart daemon
Wants=jack.service
After=multi-user.target
[Service]
Type=forking
User=patch
Group=realtime
ExecStart=/home/patch/jack-capture-tmux.sh
[Install]
WantedBy=jack.service
This is how it looks right now …after a lot unsuccessful tinkering
One step closer again! Got rid of all the errors and warnings!
[Unit]
Wants=jack.service
[Service]
Type=forking
Environment="XDG_RUNTIME_DIR=/run/patch/1000" # this was fixing all the errors
User=patch
Group=realtime
ExecStart=/bin/bash /home/patch/screen-test.sh # adding /bin/bash was fixing a new "bug"
[Install]
