Cannot connect. App does not detect anything.
Updated all the packages (apt), used all the options (no sap, etc)
Using a Samsung 10.
Thanks for your help.
Using a Samsung 10.
Hey, what is the output of this command:
sudo systemctl status pisound-ctl
Did you turn on discoverable mode on the Raspberry Pi? This can be easily done by holding the Pisoundās button down for 3-4 seconds (count the blinks). Then it will remain discoverable for 180 seconds, and keeps the MIDI LEDs will blink for that duration.
First, thanks for your reply!
Yes, Iāve turned discovery on. Iāve turned on vĆa software ($patchbox->bluetooth) and hardware (pressing buttons). Both in desktop and console mode.
The device is not shown, neither in the app or the phone bluetooth screen.
Thanks again for your help
Can you please post the output of the command here? What is the Raspberry Pi version youāre using?
Raspberry Pi 3B
patch@patchbox:~ $ sudo systemctl status pisound-ctl
\u25cf pisound-ctl.service - Bluetooth service for Pisound companion app.
Loaded: loaded (/lib/systemd/system/pisound-ctl.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2021-03-20 23:10:37 GMT; 1 day 17h ago
Main PID: 419 (pisound-ctl)
Tasks: 14 (limit: 2199)
Memory: 7.5M
CGroup: /system.slice/pisound-ctl.service
\u251c\u2500419 /usr/bin/pisound-ctl
\u251c\u2500913 /bin/sh /usr/bin/mec /etc/mec-blokas.json
\u251c\u2500917 osc2midi pisound-ctl 127.0.0.1 38735
\u2514\u2500919 mec-app /etc/mec-blokas.json
Mar 20 23:11:09 patchbox pisound-ctl[419]: mec api initialise
Mar 20 23:11:09 patchbox pisound-ctl[419]: mecapi_proc start
Mar 20 23:11:09 patchbox pisound-ctl[419]: mec_app running
Mar 20 23:11:09 patchbox pisound-ctl[419]: MecApi::MecApi
Mar 20 23:11:09 patchbox pisound-ctl[419]: MecApi_Impl::init
Mar 20 23:11:09 patchbox pisound-ctl[419]: KontrolDevice initialise
Mar 20 23:11:09 patchbox pisound-ctl[419]: KontrolDevice::init
Mar 20 23:11:09 patchbox pisound-ctl[419]: kontrol device : listening on 6050
Mar 20 23:11:09 patchbox pisound-ctl[419]: KontrolDevice::init - complete
Mar 20 23:11:12 patchbox pisound-ctl[419]: KontrolDevice::new client 127.0.0.1 : 40051 KA = 5
additional info
sudo systemctl status bluetooth
\u25cf bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2021-03-20 23:10:43 GMT; 1 day 17h ago
Docs: man:bluetoothd(8)
Main PID: 555 (bluetoothd)
Status: āRunningā
Tasks: 1 (limit: 2199)
Memory: 1.9M
CGroup: /system.slice/bluetooth.service
\u2514\u2500555 /usr/lib/bluetooth/bluetoothd --compat --noplugin=sap
Mar 20 23:10:42 patchbox systemd[1]: Starting Bluetooth serviceā¦
Mar 20 23:10:43 patchbox bluetoothd[555]: Bluetooth daemon 5.50
Mar 20 23:10:43 patchbox systemd[1]: Started Bluetooth service.
Mar 20 23:10:43 patchbox bluetoothd[555]: Starting SDP server
Mar 20 23:10:43 patchbox bluetoothd[555]: Excluding (cli) sap
Mar 20 23:10:43 patchbox bluetoothd[555]: Bluetooth management interface 1.14 initialized
Mar 20 23:10:43 patchbox bluetoothd[555]: Failed to set privacy: Rejected (0x0b)
Mar 20 23:10:43 patchbox bluetoothd[555]: Endpoint registered: sender=:1.7 path=/org/bluez/hci0/A2DP/SBC/Source/1
Mar 20 23:10:43 patchbox bluetoothd[555]: Endpoint registered: sender=:1.7 path=/org/bluez/hci0/A2DP/SBC/Source/2
Iāve just checked on Raspberry Pi 3B, it worked just fine. The bluthoothd command line was not modified from original, this is the output I got:
patch@patchbox:~ $ sudo systemctl status bluetooth
ā bluetooth.service - Bluetooth service
Active: active (running) since Tue 2021-03-23 08:37:11 GMT; 15min ago
Main PID: 528 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 2062)
āā528 /usr/lib/bluetooth/bluetoothd
Mar 23 08:37:11 patchbox systemd[1]: Starting Bluetooth service...
Mar 23 08:37:11 patchbox bluetoothd[528]: Bluetooth daemon 5.50
Mar 23 08:37:11 patchbox systemd[1]: Started Bluetooth service.
Mar 23 08:37:11 patchbox bluetoothd[528]: Starting SDP server
Mar 23 08:37:11 patchbox bluetoothd[528]: Bluetooth management interface 1.18 initialized
Mar 23 08:37:11 patchbox bluetoothd[528]: Sap driver initialization failed.
Mar 23 08:37:11 patchbox bluetoothd[528]: sap-server: Operation not permitted (1)
Mar 23 08:37:11 patchbox bluetoothd[528]: Endpoint registered: sender=:1.8 path=/org/bluez/hci0/A2DP/SBC/Source/1
Mar 23 08:37:11 patchbox bluetoothd[528]: Endpoint registered: sender=:1.8 path=/org/bluez/hci0/A2DP/SBC/Source/2
Mar 23 08:37:11 patchbox bluetoothd[528]: Failed to set privacy: Rejected (0x0b)
patch@patchbox:~ $ uname -a
Linux patchbox 5.10.11-v7+ #1399 SMP Thu Jan 28 12:06:05 GMT 2021 armv7l GNU/Linux
By the way, the App must ask for location permission - did you grant that permission? If not, Bluetooth on Android wonāt work. See here for why itās required: https://blokas.io/pisound/docs/pisound-app/#why-is-the-location-permission-required
Yes, location permissions are granted.
Just reinstalled the app. No change.
But I have just made an interesting findingā¦
Patchbox is not visible from my phoneā¦but I can see it in my PC bluetooth, so definitely and luckily is not a bluetooth problem, but an app/samsung issue
Uninstall - reboot phone - install - reboot phone - worked!!
Iām having the same issue with the latest Patchbox OS (bullseye), apparently fails after installing the MODEP module, any help appreciated! Thank you ![]()
Some output:
Active: active (running) since Mon 2022-05-23 20:12:08 BST; 3min 21s ago
Main PID: 727 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4915)
CPU: 87ms
āā727 /usr/libexec/bluetooth/bluetoothd
May 23 20:12:08 patchbox systemd[1]: Starting Bluetooth service...
May 23 20:12:08 patchbox bluetoothd[727]: Bluetooth daemon 5.55
May 23 20:12:08 patchbox systemd[1]: Started Bluetooth service.
May 23 20:12:08 patchbox bluetoothd[727]: Starting SDP server
May 23 20:12:08 patchbox bluetoothd[727]: Bluetooth management interface 1.21 initialized
May 23 20:12:08 patchbox bluetoothd[727]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
May 23 20:12:08 patchbox bluetoothd[727]: sap-server: Operation not permitted (1)
May 23 20:12:08 patchbox bluetoothd[727]: Failed to set privacy: Rejected (0x0b)
May 23 20:12:17 patchbox bluetoothd[727]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSink/sbc
May 23 20:12:17 patchbox bluetoothd[727]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/sbc
and from pisound-ctl
ā pisound-ctl.service - Bluetooth service for Pisound companion app.
Loaded: loaded (/usr/lib/systemd/system/pisound-ctl.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Mon 2022-05-23 20:15:22 BST; 2s ago
Process: 1367 ExecStart=/usr/bin/pisound-ctl (code=exited, status=203/EXEC)
Main PID: 1367 (code=exited, status=203/EXEC)
CPU: 4ms
I was able to get rid of the sap error by passing the --noplugin=sap to the ExecStart configuration.
Currently:
patch@patchbox:~ $ systemctl status bluetooth.service
Active: active (running) since Mon 2022-05-23 20:33:10 BST; 3s ago
Main PID: 1016 (bluetoothd)
Status: "Running"
CPU: 78ms
āā1016 /usr/libexec/bluetooth/bluetoothd --noplugin=sap
May 23 20:33:10 patchbox systemd[1]: Starting Bluetooth service...
May 23 20:33:10 patchbox bluetoothd[1016]: Bluetooth daemon 5.55
May 23 20:33:10 patchbox systemd[1]: Started Bluetooth service.
May 23 20:33:10 patchbox bluetoothd[1016]: Starting SDP server
May 23 20:33:10 patchbox bluetoothd[1016]: Excluding (cli) sap
May 23 20:33:10 patchbox bluetoothd[1016]: Bluetooth management interface 1.21 initialized
May 23 20:33:10 patchbox bluetoothd[1016]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/sbc
May 23 20:33:10 patchbox bluetoothd[1016]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/sbc
May 23 20:33:10 patchbox bluetoothd[1016]: Failed to set privacy: Rejected (0x0b)
Exact same error here as well.
I tried a fresh install - worked perfectly. The moment I installed the Modep module the Bluetooth fails.
Tried adding the extra flags (āexperimental (from a previous thread) as well as the others mentioned on this thread) and the same privacy error occurs.
Iāve also tried making bluetoothctl trust my phone. No dice.
Exact same issue for me. Any fix yet?
I figured it out yesterday and went to sleep right after finishing what I was working on lol. Hereās how I did it:
Steps / tldr:
/usr/bin/pisound-ctl and put it somewhere safe (ie. home directory)/usr/bin/pisound-ctl with the copy you made in step 3pisound-ctl service will auto-restart. Put your Pisound in pairing mode and connect with the app!Explanation:
So after starting from a fresh install, I realized that the exact same Bluetooth errors mentioned earlier in this thread were still there, yet the Pisound app worked just fine:
Active: active (running) since Tue 2022-05-17 14:32:39 BST; 1 months 6 days ago
Main PID: 808 (bluetoothd)
Status: "Running"
CPU: 76ms
āā808 /usr/libexec/bluetooth/bluetoothd
May 17 14:32:38 patchbox bluetoothd[808]: Bluetooth daemon 5.55
May 17 14:32:39 patchbox bluetoothd[808]: Starting SDP server
May 17 14:32:39 patchbox systemd[1]: Started Bluetooth service.
Jun 23 23:54:59 patchbox bluetoothd[808]: Bluetooth management interface 1.21 initialized
Jun 23 23:55:00 patchbox bluetoothd[808]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
Jun 23 23:55:00 patchbox bluetoothd[808]: sap-server: Operation not permitted (1)
Jun 23 23:55:00 patchbox bluetoothd[808]: Failed to set privacy: Rejected (0x0b)
Jun 23 23:56:01 patchbox bluetoothd[808]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSink/sbc
Jun 23 23:56:01 patchbox bluetoothd[808]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/sbc
Jun 23 23:56:01 patchbox bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
And I remembered pisound-ctl being in an auto-restart loop, and when I tried to execute it myself earlier with MODEP installed, it gave an exec format error, implying the binary was never going to run, no matter what settings were tweaked in the system.
So given that the executable was not giving this error before MODEP was installed, I concluded that the MODEP installation was improperly modifying /usr/bin/pisound-ctl, causing the error. Iām not sure if this is intentional, but when I replaced the post-MODEP version with a backup of the pre-MODEP version, everything worked flawlessly. I was expecting the Pisound app to not be able to see my MODEP pedalboards or something, but nope. Everything works exactly as expected!
Itās also worth noting that the Bluetooth errors are still present after this fix - but they donāt seem to cause any issues. I have my Pisound set up to transfer mp3s over Bluetooth, and it hasnāt failed to connect/transfer once.
Hope this helps!
(Also dev team, this should be easy to replicate on a RPi 4B 8GB, but if you need any more information lmk
Hey, that works! Shout out to @cjbell for doing the heavy lifting! Iāve been dealing with this issue since I got the device a few weeks back.
I should note that Iām experiencing frequent bluetooth dropouts/disconnections with the device, now that Iāve gotten past this bug. I think the dev team should probably work on smoothing this experience out a bit.
I personally probably will limit the amount that I twiddle with settings via the phoneāmostly will use the app to do the MIDI learn and switch patches.
Interesting, MODEP install should have nothing to do with /usr/bin/pisound-ctl, weāll see if we can reproduce the problem.
Fixed in pisound-ctl package, since version 1.03-8. There was some packaging problem with previous version.
Now no workaround will be necessary, if you have a problem, itās enough to update your apt packages.
Coming back after a couple months away from the Pisound.
Updated as stated above.
What I observe:
-connection works sporadically without much of a pattern
-I cannot enter bluetooth pairing mode on pisound unless Iām running with a monitor attached logged into either desktop or console. I use āautologinā
-I usually cannot reconnect to the pisound with the phone unless I enter pairing mode on the pisound (reconnection without pairing mode enabled is not working reliably)
-having the monitor attached seems enough to solve the issue??? Why should it care if the Hmdi cable is attached when booting?
Does this make any sense at all?
Can patchbox run headless?
What output does this command give you:
apt show pisound-ctl
Iāve just tried on a fresh Patchbox OS image, with all updates from apt installed, to start some Pure Data patches, and hadnāt encountered any issues, regardless of the HDMI state or ābootā options.
One thing I had to do is to remove the old pairing in Bluetooth settings on my Android phone, so a new one could be made. After that, everything seems smooth, no disconnects.
I just did a fresh install of Patchbox, following all instructions precisely.
Iām finding I can sometimes connect but not reliably. 95% of the the time I get a connection error. Of the remaining 5% of the time it connects, 95% of the time it fails within a few minutes.
Hereās what I see when I run the suggested command:
patch@patchbox:~ $ apt show pisound-ctl
Package: pisound-ctl
Version: 1.03-9
Priority: optional
Section: sound
Maintainer: Blokas Labs <hello@blokas.io>
Installed-Size: unknown
Depends: libc6 (>= 2.19), libstdc++6 (>= 4.9.2), libgcc1 (>= 1:4.9.2-10), libdbus-1-3 (>= 1.8.2), git (>= 1:2.1.4), osc2midi (>= 1.0-1), pd-blokas (>= 0.1.1-3), pisound-ctl-scripts-common (>= 1.03-6), mec-blokas (>= 0.1.1-2)
Recommends: pisound-ctl-scripts-system (>= 1.03-6)
Suggests: blokas-puredata-patches (>= 1.0), pisound-ctl-scripts-puredata (>= 1.03-6)
Download-Size: 257 kB
APT-Sources: http://apt.blokas.io rpi/main armhf Packages
Description: Bluetooth service for Pisound companion mobile app.
See https://blokas.io/pisound for more information.
Any help appreciated.
