When I click on an object in the current preset, the editor displays the properties in the properties window. Good.
When I click on any object in the pipes, the properties window clears. Still good.
If I go back and click on the SAME object in the current preset I clicked on in #1, the property window is still empty. Bad.
If I click on any other than the #1 object in the current preset, the property window displays correctly. Good.
It’s a small thing, but I thought you all would like to know.
