Is there a pipe I can use to shuffle a midi clock to send to a drum machine that doesn’t have shuffle? I’ve had a look around and can’t find anything and thought I’d seen the question on here before but can’t find an answer. Thanks!
OK I found a workaround. I was trying to shuffle a sequential drumtraks which does actually have shuffle but the shuffle applies to 8th notes or something so is pretty useless. But if you double the tempo and program the beat in halftime it works so I duplicated the pipe sending the clock to the drumtraks and can program it now.
