Show Midi Plugins in Plugin Finder
It was discussed on another thread:
Opened this as a new topic as it’s not only related to the Midi Channel Filter.
This can be fixed in the mod-ui client. Ugly, but it works :see_no_evil:
Following will put MIDI plugins to the MIDI category and unknown plugins to a new category called Other.
Modifiy /usr/share/mod/html/index.html and add following lines to the div called plugin-results-wrapper:
<div id="plugin-results-wrapper">
  <div id="effect-content-MIDIPlugin" class="plugins-wrapper"></div>
  <div id="effect-content-Other" class="plugins-wrapper"></div>
</div>
and add following li’s to the js-category-tabs ul:
<ul class="clearfix js-category-tabs">
  <li id="effect-tab-MIDIPlugin">MIDI</li>
  <li id="effect-tab-Other">Other</li>
</ul>
In /usr/share/mod/html/js/effects.js modify the function renderNextPlugin thats embedded in the showPlugins function to:
function renderNextPlugin(c) {
            if (self.data('showPluginsRenderId') != currentRenderId) {
                // another render is in place, stop this one
                if (callback) { callback() }
                return
            if (renderedIndex >= pluginCount) {
                // if we get here it means we finished rendering
                self.effectBox('calculateNavigation')
                if (self.data('showPluginsRenderId') == currentRenderId) {
                    // no other renders in queue, take the chance and reset the id
                    self.data('showPluginsRenderId', 0)
                return
            plugin   = plugins[renderedIndex]
            category = plugin.category[0]
            self.effectBox('renderPlugin', plugin, self.find('#effect-content-All'))
            if (FAVORITES.indexOf(plugin.uri) >= 0) {
                self.effectBox('renderPlugin', plugin, self.find('#effect-content-Favorites'))
            if(!category){
              category = (plugin.label.match(/MIDI/gi) || plugin.name.match(/MIDI/gi)) ? "MIDIPlugin" : "Other";
            if (category && category != 'All') {
                self.effectBox('renderPlugin', plugin, self.find('#effect-content-' + category))
            renderedIndex += 1
            c = c || 0;
            if (c < 20) renderNextPlugin(c+1);
            else setTimeout(renderNextPlugin, 1);
Don’t know how to highlight code, so put this:
            if(!category){
before:
That’s nice, could you post a screenshot of what’s the end result of the category? :slight_smile:
The Other category:
The Midi category:
@Giedrius did you encounter problems with the fix in the original template?
Currently working on a responsive mobile template and my screens might slightly differ from the original version :joy:
Looking good! I haven’t tried it out yet, but if it’s working well, it’d make sense to include the changes when updating to 1.10.
Sure, my solution works well and it’s just one line of code, but it’s quite an ugly hack.
Do I understand right that we only have access to the compiled mod-ui/utils? Midi Channel Filter - #6 by Giedrius. If not, I would recommend to fix it directly in utils_lilv.cpp.
It seems that meanwhile moddevices corrected it: mod-ui/utils_lilv.cpp at master · moddevices/mod-ui · GitHub
No, we can build the binaries as needed. If it’s fixed in 1.10, then no extra changes would be necessary then. :slight_smile:
Thats good news! In the meantime you can use my hack :yum:
