I’m having some trouble finding any documentation on how to switch pedal boards through midi. I’m using an Arturia BeatStep as my midi controller. Using the bundled configuration software I can send program changes from the BeatStep anytime I press one of the chosen buttons. I’ve included a screenshot that shows the message the buttons are supposed to send. All the top row of buttons send Program Number 0-7, and they are all on Bank LSB 0 and MSB 0. I’ve tried sending the message on the global channel, and on channel 16 (because I’ve seen some posts refer to this). Nothing seems to happen when I press the buttons.
I have created only a single bank, and I have assigned 3 pedal boards to it. Hitting the first few buttons I would assume should swap between them… First bank would be 0, and then the pedalboards would be assigned to the program change numbers. That’s my assumption because I can’t find any documentation for this. What am I doing wrong?
Edit: Also wondering, is there a way to switch snapshots with MIDI?
