Select ORAC preset using The Button - possible?
Is it possible to select/cycle through ORAC presets using the pisound Button?
I could imagine triggering a shell script that sends ORAC some OSC. But I can also imagine that it’s maybe not documented :smile:
Source code is the only kind of documentation which always gives the correct information. :wink:
I think you have to send the OSC message to the IP running MEC on port 6000.
To understand what arguments to use, searching the source code for the ‘loadPreset’ call, you can trace it to this location:
You should be able to find out how the Rack Id looks like by inspecting the MEC logs (sudo journalctl -u mec), I suspect it could always the same value, and what argument to give for the preset by inspecting the code above and your file system.
Thank you, that’s a great start. I think this would be a great bit of functionality to go with the ‘headless synth’ concept, so I’ll see where I get to.
