I have a Pisound-setup with MODEP installed,
that I actually use as a simple synth using the LV2 Fluid-pedals to generate synth sounds.
Now I may need to trigger some specific samples live, and was wondering if I could solve that using the same MODEP-installation (just create a new virtual pedalboard).
However I do not know how to install additional ‘pedals’, if I would be so lucky to find a LV2-based sampleplayer pedal that works with MODEP, nor do I know how to load the soundlibrary for that sampleplayer. I can prep the samples in any format needed though; that would be the least of my worries.
I guess the simplest way would be to take one of those FluidGM pedals, change the name of it and associate it with a new soundlibrary (which would be those custom samples)
and then somehow transfer that LV2-file and library onto some directory on the RPI that MODEP could discover.
Anyone here that could help?
TIA
cheers,
V72
