Hello
I wanted to see if someone could help me understand pisound a little bit better. Currently I am trying to run the examples from the portaudio repo, but the output is coming from the rpi jack. I tried writing a .asoundrc like this:
pcm.!default {
type hw
card 1
pcm.!default {
type hw
card 1
But with no change. aplay -l returns this:
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 7/7
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
Subdevices: 1/1
card 1: pisound [pisound], device 0: PS-3S8GG17 snd-soc-dummy-dai-0 []
Subdevices: 0/1
I have not been successful in getting sound from the output from the pisound yet. I know portaudio can probably find it because running ./pa_devs from /portaudio/bin/ gives me this:
--------------------------------------- device #2
Name = pisound: - (hw:1,0)
Host API = ALSA
Max inputs = 2, Max outputs = 2
Default low input latency = 0.0080
Default low output latency = 0.0080
Default high input latency = 0.0320
Default high output latency = 0.0320
Default sample rate = 48000.00
Supported standard sample rates
for half-duplex 16 bit 2 channel input =
48000.00, 96000.00, 192000.00
for half-duplex 16 bit 2 channel output =
for full-duplex 16 bit 2 channel input, 2 channel output =
So I guess I am taking this opportunity to maybe learn something if someone is kind enough. Why when I run alsamixer it shows PulseAudio as the default card? I am curious about what is going on behind the scenes, because thanks to the forum I learned the speaker-test command but it only outputs from the pisound when I turn off jack. I also learned that aplay sample.wav outputs to the rpi jack, while to output from the pisound I have to do aplay sample.wav -D sysdefault:CARD=1.
I am running patchbox. I am new to the forum so if there is anything I should have put here let me know.
