Some times i move the sd card in the Raspberry Pi hardware that has the pisound plugged and install to a separate Raspberry Pi without the hardware attached.
When I used the command alsamixer it says it cannot open mixer when the files are still there. Thats typically where i also adjust what sound card im using.
How can I use alsa again and also how can I playback sound of the same OS that I have pisound installed but without the pisound hardware attached?
So prior to installing pi sound. I would use, i think it was, the alsa sound card being used.
If I were to remove the pisound hardware after installing the pisound libraries, the RPI for some reason cant use devices such as alsamixer. It works however again when I attach the pisound back
This seems to be an issue with your OS image - it can’t locate the alsamixer executable. Running alsamixer on my system based on Raspbian Lite runs the command just fine…
its odd. When the Pisound is detached and i use the command:
which alsamixer
its does say /usr/bin/alsamixer
but when i use the full path :
/usr/bin/alsamixer
its says:
cannot open mixer: No such file or directory
edit: Im also noticing when i run alsamixer with Pisound attached its there but I can’t adjust volume with it. It actually just shows a bar saying 00 with the meter going up from green through white into red. Which is causing clipping, except I can turn the audio down in the program Im using to playback audio( which is ecasound). Despite this the bar remains the same
