Replace soundfonts in AirFluilyd320
I’ve installed MODEP, really satisfying but I don’t like so much the Grand Piano sound. So, I’d like to replace even the entire bank with with the .sf2 soundfonts I use on fluidsynth on ubuntustudio. Is It possibile? I saw that in /usr/share/sounds there isn’t a soundfonts directory.
Hey, the steps for building fluidsynth are in this script: https://github.com/BlokasLabs/modep/blob/modep/stage4/00-install-plugins/scripts/fluid.sh
You may just delete the plugins from your /usr/local/modep/.lv2/… folder and build and install your own version as you see fit. :slight_smile:
Great! Thanx, I’m gonna trying!:slight_smile:️
