Hi
I was interested to here any advice on the following idea.
I’m moving a recording from ableton to my raspberry pi y bouncing all the stems and then using a text based DAW on raspbian lite to mixing the audio stems/recordings.
there are however around 40 audio stems. Have I run into a problem here by expect the pi to play that back simultaneously?
