A eurorack faceplate, breakout boards, and specs for a rack mounted rasbpi kit that will run patchbox.
Could this be used with the pisound board?
With DIY magic, everything is possible.
But as Pisound’s input & output volume controls are fully analog, it’d make sense to unsolder the pots and to place them on the faceplate, so volumes could be easily adjusted. It looks like there’d be not enough space on the plate for that…
