Hi everyone !
Enjoying my Midihub. I generate random notes with random LFO, harmonies, chance pipe, dispatcher, etc. So cool, so fun !
Everything works fine except one pipe : scale pipe.
Because I’m not a dodecaphonic guy, I put a scale pipe for a minor scale (some degrees are mapped if I need to). Some times it works fine, scale pipe doing his job. But most of the time, it’s too much of a job. It gets stuck on G and D (though at different octaves).
I’ve tried a few things. As I don’t understand the “transpose C to Base” I click that thing and it works fine for a few seconds and it get stuck again on G and D.
In order to show you this issue, I tried to upload my patch but it seems I can’t. Here’s a few screenshots :
You can see that some of theses notes should be played but it discards them all except for G and D…
Thanks for your help !
I think it might be to do with what Giedrius explained here
btw, dunno why you can’t upload, I thought it was only very new users who didn’t have that access…
Well. First I’d like to thank you for caring. I think the issue is because of harmonizer. If I bypass this harmonize pipe, scale pipe seems alright ! maybe it doesn’t like too much data…
Oops ! answer too fast. Problem not solved. Even without harmonizer, with an additional chance pipe placed just after LFO+transformer pipes (for having less data in the pipeline) scale gets stuck on Gs and Ds…
try posting up your patch again (either here or in a message to me) and I’ll take a quick look.
My guess is the answer will fit with G’s design of Scale Remap…
Try this version of your simplified patch
pydarian_RandomLFOtoNote.mhp
As a problem solving (/identifying!) experiment:
I’ve added a Length pipe with the length set just shorter than your 16hz noise rate (1/16 = 0.0625 =c62ms)
all notes should go through Scale Remap
now try decreasing your LFO depth (more duplicate notes)
and increasing the Length length (note more likely to duplicate before counterpart gets a Note_off)
watch your Scale Remap get “clogged up” until you click Transpose C to Base again to clear it
This illustrates Giedrius design of the pipe.
So your patch will require a bit of a redesign to stop this
PS, you might want to try making your own Sample&Hold instead of using noise…
here’s some discussion and different approaches
