New here. Just came across this intriguing piece of equipment. Can we have pipes that map/set out Chord Progressions? Distributor can go Chord 1, Chord 2, Chord 3 and Chord 4 at specified key intervals. Make sense? Thanks.
You may set up harmonizer pipes to produce specific chords, and you may have multiple horizontal pipelines combined with Note Range Filters to pick which Harmonizer gets used for which key, so it’s possible to do, but it may not be too convenient to control, it depends on how complex your idea is (like how many chords, what key range you intend to use).
Hadn’t thought of this work around. Thank you!
