Dear all,
My goal is to realize a 4 tracks loopstation using SooperLooper with an external controller (midi or osc) and Rpi as core audio device.
I installed a fresh image of PatchBox Os and make all updates automtically at first startup.
I not installed any optional package (ModeP ecc).
I try 3 different usb audio without success.
M-Audio Fasttrack c400 - No sound at all
M-Audio Fasttrack (the cheapest with 1 xlr and 1 hiz)
Works with high latency settings and crack pop sometimes
M-Audio Fasttrack Ultra
Has direct monitoring so I ear the input without latency and can set volume with alsamixer, but the loops sound bad, with some metallic sound and strange modulate/pitching issue
I try a freash raspbian with desktop, installed jackd and sooperlooper and with the Fasttrack Ultra can get 2,9ms ol latency at 88,2khz without any audio glitch.
I did several test and combinations and I had the same issues with larger buffer or different sample rate.
With rasbperry os (without any optimization) I can have 88,2 khz and 128 buffer without glitches.
With Patchbox the sounds on my Fasttrack Ultra are bad in any case…
I have a Pi 4 and a cheap 7$ usb stick audio device. I easily reach 48khz and 10ms buffer, even with heavy Sunvox patches. But that’s on default Raspbian. On Patchbox I had lots of issues so i stopped using it.
That being said, I’m very interested to know about your 4 track looper, if you want to share any details!
Dear narF,
I’m really busy at the moment, I did some small steps.
I use Mobius Looper on Windows for years and my goal is recreate my Looper with a small and portable hardware and raspberry is a great candidate.
I have a Raspberry PI 3b+, after some test, I set the freq to 48khz with 128 and It is really stable.
I use hardware monitoring for direct input monitor without any latency and SooperLooper has a built in latency compensation for keep all synchronized.
There are many difference btw Mobius and SooperLooper. I write my own scripts for Mobius, my LoopStation model is Ed Sheeran Chewie 2. I saw a lot of live performance and try to reproduce the same behaviours. With Mobius I get it. SooperLooper is based on EDP-4 Gibson Looper and Is a bit different story. I did some test and I start to develop a layer that reads input from pedalboard (is Arduino based and I can send midi or direcly byte via usb/com serial port) and translate into OSC commands for SooperLooper for achive my “looper logic”. My small layer is in .net core becouse I’m a Windows developer
