Puredata file at startup
Hello,
I’m completly new in linux environnement and raspberry too.
My hardware is : Raspberry Pi 3 Model B Plus Rev 1.4
I’ve created a Pure Data patch, it is on the Desktop and I’d like it to be executed at every startup of the raspberry pi.
On a tutorial founded on Youtube, it says to use “sudo crontab -e”.
So I opened it and I wrote the command line : @reboot puredata /home/pi/Desktop/whitenoise.pd &
(adding one empty line) and ctrl+s and ctrl-x
and back to the terminal window, I typed “sudo reboot”.
But nothing happens after rebooting the raspberry pi, why ?
I tried by changing the folder name “pi” by “patch” (I don’t know why there are two names available)
The .pd path is correct, I can launch it directly from the terminal.
below a screen capture of the crontab window
https://dbr-prod.ch/wp-content/uploads/wordpress/terminal_rasp.jpeg
thanks in advance for your help :slightly_smiling_face:
Hello Dobermann !!
You must put your pure data file in the folder /usr/local/puredata-patches/MY-FOLDER/main.pd
Your files to launch your patch must name main.pd , and it can use other patch.
After enter in console “patchbox” and select “module” and “puredata” and your module must be appear .
Patchbox wizard are a good solution into…
I hope i help you and sorry for my bad english
Hi Romger49,
Thanks for your message.
Unfortunatly it doesn’t works, I did exactly what you wrote.
The pure data patch has been renamed as main.pd and has been placed in the folder /usr/local/puredata-patches/MY-FOLDER/
below a screen capture of the terminal
Hi all,
after viewing multiple tutorials, I’ve founded a solution ! :slight_smile:
on the folder : /home/patch/.config/autostart
I’ve created a file called puredata.desktop, inside this text file:
[Desktop Entry]
Type=Application
Name=puredata
Exec=puredata /home/patch/Desktop/whitenoise.pd
StartupNotify=false
Terminal=true
and it works !
I can’t understand why it is sooooo complicated… or why programers doesn’t make an easy way…
