hi,
weird situation here… when i’m connected to my Pi over SSH I cna press the button and it launches the file ‘main’ from puredata-patches.
BUT
if i’m not connected via SSH nothing happens… if i then log in and run top i can see that pd is not running? but then pressing the button starts everything as expected.
any thoughts?
I suspect the cause of the issue was the automatic detection of a display to use (like using HDMI one if connected, otherwise try to locate any remote desktop displays, otherwise fall back to -nogui), if anyone knows better methods, let us know.
For info (not sure if it’s useful or not, depends if any changes were made to pisound download package )
I installed my first pisound on 20th March and managed to get button working with device running standalone off a battery. That time I installed puredata from terminal window. Then managed to snap the sdcard (long story!) so reinstalled OS from same raspberry stretch disc image as before, re-downloaded pisound this Monday (16th April), and this time downloaded puredata using the option in pisound-configuration. At that point the button would only launch pd when I was logged in over SSH (via X quartz on mac osx)… Until giedrius jumped on the case and helped fix it of course!!!
