I don’t know if it’s a duplicate question, but I could not find any consistent answer to this, so I’m opening a new topic.
I’d like to know if it’s possible to get (and possibly set) parameters in MODEP. I mean: pedalboard name, list of plugins in the current pedalboard, bypass state of every single pedal, list of exposed pedals parameters and their values, and so on… I tried to connect to the mod-host sockets, but I couldn’t get through to it. It seems that parameters are only addressable in interactive mode, which is not the case.
Any clue?
The mod-ui and mod-host may be having an exclusive connection to each other, so they don’t respond to other communication. The pedals themselves are instance of LV2 plugins. I think you should be able to try to access them directly using some LV2 library, like liblibv, as suggested in this topic: TouchOSC + Modep - Toggles and presets. Make sure to set the LV2_PATH to be able to see the same lv2 plugins.
Also check out this script: https://github.com/BlokasLabs/modep-btn-scripts/blob/master/modep-ctrl.py, it does some web requests to get and set information through mod-ui.
See https://github.com/BlokasLabs/mod-ui/blob/modep-1.8/mod/webserver.py#L1934 for the registered URL endpoints.
Thank you Giedrius!
Another question… Is OSC support only available through touchosc2midi or does MODEP enable a full OSC environment?
It does not support it natively.
