Hello sometime when i switch to a pedalboard that use dexed i have errors in journalctl for mod-host
There is also a missing manifest file but that is an other error i don’t know if related.
The problem here is … i switched to a pedalbord that have dexed from a pedalboard that was using fluidsynth as you can see. At first the modep-mod-host service crashed with a SEGV the mod-host cannot play anything … then the service autorestarted and this time the pedalboard start to work again.
Sometimes happen that the mod-host service crash and restart in a loop without starting the pedalboard. I suppose that there is something to fix in the dexed plugin since i didn’t have this problem with others … what can be ?
Jan 23 21:31:40 patchbox mod-host[6896]: fluidsynth: warning: No preset found on channel 9 [bank=128 prog=0]
Jan 23 21:32:58 patchbox mod-host[6896]: fluidsynth: warning: No preset found on channel 9 [bank=128 prog=0]
Jan 23 21:34:12 patchbox systemd[1]: modep-mod-host.service: Main process exited, code=killed, status=11/SEGV
Jan 23 21:34:12 patchbox systemd[1]: modep-mod-host.service: Failed with result 'signal'.
Jan 23 21:34:12 patchbox systemd[1]: modep-mod-host.service: Consumed 28.072s CPU time.
Jan 23 21:34:14 patchbox systemd[1]: modep-mod-host.service: Scheduled restart job, restart counter is at 13.
Jan 23 21:34:14 patchbox systemd[1]: Stopped MOD-host.
Jan 23 21:34:14 patchbox systemd[1]: modep-mod-host.service: Consumed 28.072s CPU time.
Jan 23 21:34:14 patchbox systemd[1]: Starting MOD-host...
Jan 23 21:34:14 patchbox mod-host[7148]: Forking... child PID: 7149
Jan 23 21:34:14 patchbox systemd[1]: Started MOD-host.
Jan 23 21:34:26 patchbox mod-host[7149]: error: failed to open file /var/modep/lv2/plugins/manifest.ttl (No such file or directory)
Jan 23 21:34:26 patchbox mod-host[7149]: lilv_world_load_file(): error: Error loading file `file:///var/modep/lv2/plugins/manifest.ttl'
Jan 23 21:34:26 patchbox mod-host[7149]: lilv_world_load_bundle(): error: Error reading file:///var/modep/lv2/plugins/manifest.ttl
Jan 23 21:34:26 patchbox mod-host[7149]: mod-host ready!
type or paste code here
