Every time I turn on my MIDIHub it loads preset 8 and I have to manually change it to preset 6. How can I make the MIDIHub remember what preset I loaded? This issue just started happening recently; I don’t remember having to ever do this before.
Problem solved. Apparently the MIDIHub on boot loads the last preset you loaded/saved explicitly through the editor (not sure which operation actually, loading or saving?)
I must have loaded/saved Preset 8 last time I used the editor so…that’s what it was loading. Wish that wasn’t the case and that it could just remember what you loaded since I don’t usually use the editor or a computer in my setup most of the time but it’s not a big deal. I loaded/saved Preset 6 which is what I’ll want for the time being.
Ah good to know. Thanks for the tip.
