Hello,
I am trying to use RTAudio with the PiSound. I currently have a real time kernel and everything seems to be working fine except because of certain constraints in my upstream pipeline, I can only support real time applications upto 16kHz. I should mention that I am playing audio through the line out. Since my target application involves speech that sampling rate is acceptable to me. However, I do not see official support for 16kHz listed in the documentation and was wondering if there was a configuration option to enable that or whether it is not officially supported but something I could get working. Additionally, I was wondering if it would be possible to use the line in at a different rate like 48kHz while the line out runs at 16kHz.
Thank you!
