hi,
pisound works very well with the pi400, but a special case was needed:
here we go
my new renoise machine
hi,
That looks very nice
Do you connect the Pisound via male <-> female ribbon cable?
no, made a adapter-pcb, cause the ribbon cable don’t work (4,8V at pisound side, think the wires are to thin for the power-rail).
Can we see just the pcb connector? did you make a case?
i will make a picture next days, but its really not space science.
do you mean i made the housing? yes i crafted to AL-sheets for top and bottom, The sides are still open now , i need to mill something out of pmma etc. , cause i forgot the LEDs
Interesting, maybe it was the particular cable, we’re using 40cm ribbon cable when testing Pisounds without an issue. ![]()
