Hi
I am only getting one channel of audio. I am exporting stereo rnbo patchers to the pisound and only the left channel works. It is not rnbo, as running speaker-test gives the same result–4 seconds of noise in my left ear.
Here is some info based on forum searching:
Power source: bundled Rpi adapter
Output of
play -l
card 0: Dummy [Dummy], device 0: Dummy PCM [Dummy PCM]
Subdevices: 7/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 8/8
card 2: pisound [pisound], device 0: PS-01X4APN snd-soc-dummy-dai-0 [PS-01X4APN snd-soc-dummy-dai-0]
Subdevices: 0/1
card 3: vc4hdmi0 [vc4-hdmi-0], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
Subdevices: 1/1
card 4: vc4hdmi1 [vc4-hdmi-1], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
Subdevices: 1/1
- Output of
sudo systemctl status jack
Unit jack.service could not be found
Finally, what command do I use to stop speaker-test? I tried
sudo systemctl stop speaker-test
And got
Failed to stop speaker-test.service: Unit speaker-test.service not loaded.
