Pisound input gain
Hi, i currently have a mackie mixer going into the pisound with modep image for master fx. The issue im having is that the volume of the mixer needs to be quite low so as not to clip the inputs of the pisound, is there a way to attenuate the input gain or will i have to buy a hardware solution ?
P.s im handy with a soldering iron so if theres a solution that involves modifying the pisound hardware i wont be shy
Thanks.
Welcome to the Blokas community Kron!
I had the same problem plugging an active bass guitar into the pisound. Unless something has changed there’s no way to pad the input on the pisound. I just wound up using the Step Ladder from Mod Electronics;
Ok, ill pick up one of those ! Thanks for your help
Just be aware that you do have to assemble the device. Unless they offer a fully assembled unit now.
