Pisound + Compute Module 4 IO Board
Hi! Is it possible to mount the Pisound on a Compute Module 4 IO Board?
We haven’t tried it ourselves, but I’m pretty sure that should work just fine, it should be fully compatible with hats meant for use with regular Raspberry Pis.
Yes you can. But you need to remove one of the nut of the audio jack cause that will comflict with the board. Pisound works totally fine on CMIO board.
