Hello!
I just make a case for the pisound to fit the RPi5 with the fan. I have to re-draw the original version in fusion 360 because I can’t achieve to import the SLDASM file. I added label on the case and ventilation ports too.
You just need a RPi headers between the RPi and the Pisound.
I will share it through thingiverse in the future.
Should I specify something for the copyright or whatever?
I love it! If you’re willing to share I would just need to find someone with a 3d printer!
Here it is!
I don’t make the 4 spacers, instead of 25mm you will need a length of 40mm.
I don’t use them on this version and it is ok. But if someone can told precisely what is the screw thread size I can design it.
@jejeremy what size GPIO extension did you use? Would you be able to link to the exact part you ordered? I’m actually having someone 3d print the case locally!
If anyone wants to order the stacking header in the US they have the same thing at Adafruit:
I’m actually having 2 different people print this. One I got for free and another im paying for. I might ultimately drill some holes in the side and use self tapping screws to go into the holes where the plastic tabs go. I already broke one off.
Hey all! The guy that printed mine locally also broke off the 2 small tabs on the side panel that goes into the box. He wound up printing 3 because of this so he has 2 spares that are missing one or more of the tabs. I am going to drill out the tabs on the side panel and just use 2 screws to attach the side panel to the box.
If anyone is interested in getting one of the spares let me know and I will put you in touch with him.
