Thanks to your support Pisound is currently near the 300% mark! Thank you very much! Nevertheless we are not done yet! Together we can take it to the next level! Here are our stretch goals:
GPIO Header Holes
Your Pisound board will come with header holes that will allow you to easily connect to the unused Raspberry Pi pins. It was quite a tricky part to expose them without using 4-layer board, so we really hope you will take a good care of them.
Mobile App
Android & iOS Apps for selecting & launching patches. The App will display the output of the console too, so you will be able to have a real-time feedback on what’s happening under the hood. Also we will add some patches to get you going!
LV2 Plugin Host
For those who haven’t already explored LV2 world, LV2 plugin format is the Linux equivalent to VST on Windows/macOS. There are already hundreds of LV2 plugins out there that you can run on your Raspberry Pi. Currently there is no convenient way to play around with LV2 plugins especially without using an external monitor or mouse. We will fix that!
