I am using an ESP32 to trigger a Pd patch running on the Pisound. The method for this is that the ESP32 connects as a Bluetooth Midi device, and sends a midi note via a button press.
This connection works great most of the time, but sometimes the ESP32 doesn’t connect to the Pisound. Restarting the ESP32 doesn’t solve the problem, so I assume that the issue might lie with the Pisound.
Is there a process that I can restart to see if this will instigate the Bluetooth Midi connection? Many thanks for your help with this in advance!
It’s not Pisound, but the Raspberry Pi providing the Bluetooth connectivity. Any information you can find on Raspberry Pi and Raspbian on this is relevant to the Pisound and Patchbox OS systems too.
Some things to know - the systemd Bluetooth service is called ‘bluetooth’, it runs a process called bluetoothd, and it can be configured through sudo bluetoothctl comamnd. Just running the sudo bluetoothctl should indicate some of the Bluetooth activity, type help, to see what commands are available.
This was super-helpful, and I was able to confirm that on the side of the Raspberry Pi (thank you for clearing up that everything related to Bluetooth connectivity is managed here) everything was set up correctly. I am now thinking that the ESP32 might be underpowered, as it’s running off 2 AA batteries. When powering the ESP32 via USB from the laptop it connects right away. Live and learn!
I need the full Bluetooth 5/BLE feature set and the information I found says RPi4B doesn’t have that.
“BlueZ Bluetooth stack supports both Bluetooth Classic and BLE, but its support for BLE is more recent and there are some limitations and sometimes bugs. Bluetooth 5.0 support on the Raspberry Pi is limited to the mandatory features. The main one that is missing is the Long Range support, so if you were thinking of leveraging the Coded PHY for extra long-range, you won’t be able to. This feature is normally not found on combo Wi-Fi + Bluetooth chipsets.”
My current solution was to order a few Bluetooth/MIDI widgets from CME
Yes, this could be a problem Nominally charged 2x AA batteries would provide only ~3.0V, while ESP32 needs stable 3.3V. If it manages to run on this low voltage, the batteries anyway would soon discharge towards 1V individually, and then drop off quickly. So you have to either use some voltage booster circuit capable of providing the required power amount to the powered circuit, or a possibly simpler solution - 9V battery with a 3.3V DC regulator. Or if it can be USB powered, a power bank may make sense.
@Giedrius I can confirm that using a 9v battery solved the problem! It’s a bit scary to see how power-hungry the wireless functionality of the EPS32 is, so I ended up revising the code to wake up the processor with the push of a button, and send it back to sleep after a few seconds to converse energy
@Rain Interesting to hear that RPi4 doesn’t support BLE, this explains the issues I’ve been having with my secondary RPi which is a v4 device! On the Pisound using a RPi3 I’ve been having great success with BLE on the EPS32, I just have to pair the device once from the RPi using the command line and then everything is good to go.
In case this is relevant to anybody in the future, the set of commands to pair a EPS32 from the RPi is as follows:
sudo bluetoothctl
scan on (find the MAC address of the EPS32 you want to connect to)
trust *MAC address*
pair *MAC address*
Oh? Trying to understand what’s implied, here. The Argenox link you shared suggests that we would use a Pi4B instead of previous models (which only support Bluetooth 4.x).
So, just to be clear… You’re getting fewer issues using BLE MIDI with a Pi3 than with a Pi4?
For context…
Coming back to my Pisound setup to do some BLE MIDI experiments… after growing increasingly tired with the way CME handles its WIDI line of devices.
Those do have some neat features… yet they fall short of the constant hype from the company. For instance, a dongle like this will disconnect for no reason and I’m just told that I should learn to reconnect quickly. Not fun if it’s supposed to be used in performance. They also hype their low latency… which requires yet another firmware update which could only be done through a PC or Android. I’ve had way better results from a Yamaha dongle which never required any update.
In this context, I’d rather come back and have fun with Pisound. Maybe it’ll be difficult to setup. At least I’ll learn some things. And I can do many more things to the MIDI messages than with those WIDI dongles.
