Pc-12 Midi controller routing
Hello I have four pieces of gear that I am trying to connect. An elektron octatrack is used to control tempo and program changes to a Digitone and a syntakt. On the top of the midi chain is a faderfox pc12 channel midi controller. On preset 1 the midi controller is routed thru the midihub to the syntakt. The 12 channels of the syntakt are set to 1-12.
In preset 2 The octatrack is again master tempo and program change to the Digitone and syntakt. The faderfox pc-12 is routed to the octatrack and digitone IN. Channel 1-8 controls the octatrack and 9-12 are set to the Digitone.
The idea behind this system to is quickly have all 72 pots in the pc-12 dedicated to all 24 audio tracks between two pages.
Please see the attached drawing to explain.
I just received my midihub and set everything up accordingly. It seemed fairly straightforwad setting the midi IN and OUT routes internally in the midi hub on presets 1&2… I also programmed the pc-12 encoder button to send a program change message on channel 16 (cc1 on preset 1 & cc2 on preset 2) to avoid needing to cycle the button on the side of the hub.
I got it al plugged in and…disappointment
The tempo and program changes are working but the pc-12 was hit and miss. I watched the midi info pass thru the hub via my computer and it all looked like it should be working. The octatrack wasn’t responding to input from the pc-12 and the digitone intermittent. The syntakt seemed to work fine. I’m thinking perhaps I created some sort of midi loop with the octa track that was messing with me. Can anyone think of a reason that a track mute cc sent thru the hub to an octrack wouldn’t trigger?
Hi, please upload your preset here, so we can see if there’s any issue with it.
IMG_3861
Midihub 2023.01.08 21.44.14 (Preset 2).mhp (456 Bytes)
Midihub 2023.01.07 21.55.21 (Preset 1).mhp (431 Bytes)
The port names don’t seem to match up with your drawing - it shows for example that Octatrack input is hooked up to Midihub’s Out B port, but the OCTA IN port name in the preset actually refers to Midihub’s Out A port.
Btw, if you are seeing messages getting dropped randomly somewhere in the chain, it could be due to a malfunctioned cable - I’ve had one cable fail like that in the past, replacing it fixed the drops.
thanks for catching this, i’m pretty sure that the drawing is just mislabeled as i drew it from memory. when i had it all hooked up, i remember seeing the orange lights on the midihub blinking in such a manner that it seemed to be routed correctly. Ill check into this and the cables. thanks
