Orac question: Braids out of Tune
I finally got ORAC up and running on my PiSound today, and am generally really excited about it. However, I noticed that the “Brds” synth seems to be tuned between two semitones, and it doesn’t seem possible to fix it within Orac (the tuning knob in the module does not allow for fine tuning). It also seems to be a problem with this “macrosynth” module, which is also based on a Mutable Instruments synth.
Does anyone know what the cause of this might be, or how to fix it? I’d love to get it in tune so I can play that particular synth with my band without everyone else having to detune.
Thanks for any help you can provide!
I got the same thing and the solution was to switch the audio sample rate between 44.1 and 48khz. In the jack settings (using patchbox-config) I’m currently using a usb soundcard, not a pisound
I have the same problem. All the MI synths are out of tune - I’ve tried 44.1k, 48k and 996k but they’re all about 130cents out of tune. I’ve confirmed the samplerate is 48k and rebooted etc:
patch@patchbox:~ $ jack_samplerate
48000
Is there anything else I should try?
