One note to initialize all CCs
Hi!
I’m thinking about a pipe that, once received certain note on one MIDI channel (from an Octatrack connected to Midihub In A), transforms this trigger in sending value 0 to ALL CCs to some specific port (where a Faderfox is connected, Midihub Out D), so all these CCs are initialized in the Faderfox -check “diagram” :smiley:
I’m thinking about a From A → CH Filter → Dispatcher → Transform Note into CC → To D
But not sure if this is correct, and I would need some help here! :slight_smile:
So all CCids meaning one event in will create 128 outgoing?
16 Transforms to note ids 0,8,16,…,120 then see [2] below. 18 pipes but instantaneous
Or you can try the LFO route
  1. A 1-shot LFO (saw-up, 128hz res) would give 128 CC values which you can then Transform to 128 ids all with value 0.
    that would take 1 second. 2 pipes.
  2. If that’s too long you can do it at 8Hz ( giving values 0,8,16,…), Transform them to notes (on some unused channel), Harmonize them to get 8 notes from each one, then Transform the notes to your CCs.
    that brings you down to 1/8 sec. 4 pipes
  3. If that’s too long, you could try several 1-shots with different phases running at 16 Hz or more
There might be a nicer way but that’s the best I can think of now.
Thanks for replying! I finally just needed a couple ccs so I created 16 pipes, one for each encoder, and transform note into cc and works ok
Thanks again!
