Nord 3p split to separate midi channels
Hello, I suspect what I’d like to do is pretty simple but fairly new to all this. Hoping to live record on a nord 3p into digitakt sequencer and have each nord pad come in on its own channel (midi track in digi). The nord outputs all 6 pads on the global channel (10). I’d like to listen for the note data and split each note to its own channel. Something like:
note 60 on ch. 10 > note 60 on ch. 1
note 62 on ch. 10 > note 62 on ch. 2
note 64 on ch. 10 > note 64 on ch. 3
note 65 on ch. 10 > note 65 on ch. 4
note 67 on ch. 10 > note 67 on ch. 5
note 69 on ch. 10 > note 69 on ch. 6
Thanks.
Use the Dispatcher pipe, it will rotate every new note to a new channel, choosing only from the enabled channel numbers in its parameters.
My example address each note individually… also doable alternative :wink:
So, for example note 60 will be always on CH 1
Ch Remap Nord3P notes.mhp (875 Bytes)
edit: just adjust/select the in/out you want (I saved using USB IN >USB OUT
This is exactly what I was after, thanks a lot! Just out of curiosity, would the notes always end up on different channels if one went the dispatcher route?
Yes.
From the manual:
Dispatcher
“ A modifier pipe that upon receiving a note message dispatches it to different channels, rotating and keeping track of empty slots.”
That was my understanding, thanks.
