Noise on cc lfo
Is it right that the noise choice on the cc lfo pipe doesn’t respond to clock, so that it could be more like a sample and hold?
Yes, it does not respond to clock at the moment. Do you want a random value to be generated at fixed time intervals?
Yes, similar to a sample and hold
I also stumble on this… did not bother me.
Managed to do it using a square lfo into a random pipe set to cc,
Also. Managed to do it by transforming noise lfo Cc to note then through a chance, then transforming back to Cc , the first method was clock controlable But the second method just thinned out the cc data.
Bump, this seems bizarre to me.
Surely it should be every (rate), generate a new value?
Also, the resolution seems to alter the rate!!
We’ll note down adding a sample and hold waveform that would sample & hold the incoming CC (if LFO is placed as a modifier), or the internal noise waveform (in case it’s placed as a generator)
