I also have a Yamaha electronic drum kit with a MIDI out
I would like to record the drums using the MIDI signals (I have been doing it acoustically, happily, but more fun is better)
I have never done anything like that.
Is there software that I can run on the Pi that will let me connect the MIDI out on the drums to the MIDI in on the Pisound and record the MIDI events?
I am assuming I can then process it in a DAW like Ardour or in Hydrogen…
@worik I was going to suggest that you use MODEP and just feed the MIDI into one of the available drum generators (like FLUIDGM or one of the Black Pearl plugins) then use the sc_record plugin to record the audio…but then realized that the drum generators are not in Patchstorage! Imagine my embarrassment!
So I will check why those are not in Patchstorage over the weekend. That could be a very easy way to create audio recordings without needing MICs.
Of course…the other option is to run the audio output of your drums in to MODEP and use the same sc_record plugins to capture the audio. Then you could also add some reverb, delay, etc.
