Hi everyone,
I need some advice on optimizing my MIDI setup for both live performances and songwriting. Here’s what I’m working with:
- Various synthesizers and MIDI-enabled instruments
- A small setup for live performances
- A larger setup for songwriting
- Retro Kits RK-008 MIDI recorder
- Blokas Midihub
The Goal: I want to use the RK-008 to record and play back MIDI performances in both setups. My aim is to have the RK-008 act as both a MIDI source and receiver, allowing me to capture and play back MIDI data seamlessly across my devices.
The Problem: When I connect the RK-008 to my MIDI chain and try to loop the MIDI clock back into it, the clock data causes a feedback loop, making the RK-008 “freak out.” This clock loop issue disrupts the setup, making it unusable for my needs.
Potential Solutions:
- Purchase an RK-006:
- This seems like an easy solution since it’s designed to handle more complex MIDI routing, but I already have a Blokas Midihub, which should be capable of managing this.
- Use Blokas Midihub:
- I could use the Midihub to route MIDI in a way that filters out the clock signal where necessary. This would involve sending the MIDI out from all devices (last in the chain) to the Midihub, filtering the clock out, and then sending it back to the RK-008.
- Other Solutions:
- I’m open to suggestions on other possible setups or configurations that might work better.
Additional Context:
- My current understanding is that using the Midihub should allow me to manage MIDI clock signals effectively, avoiding the feedback loop issue.
- Ideally, I want to keep the setup portable and flexible, allowing me to bring the RK-008 to different setups and use it both as a source and a receiver of MIDI data.
Has anyone faced a similar issue or can anyone provide guidance on the best way to set this up? Any advice or recommendations would be greatly appreciated!
If the right way is to just use Midihub, I would love it - but I am feeling a bit confused on the proper way to structure the pipe.
Thanks in advance for your help!
