Is there a way to run PureData patches alongside the Modep environment?
It’s possible, after installing MODEP, you may then activate the Pure Data module to autostart your patch, and enable MODEP in parallel manually by running:
sudo systemctl enable modep-mod-ui # This makes it run on reboot automatically
sudo systemctl start modep-mod-ui # This makes it run now
You can use stop and disable in the middle of the command for reverse effect.
THANK YOU
much appreciated
